PIS-0797
PIS-0797
    PISUPPLY
    PI-HOLE THE NETWORK-WIDE AD BLOC
PIS-0797 数据手册
          Pi‐hole ‐ The Network‐Wide Ad Blocker Pi Supply and Pi‐hole have partnered together to bring you the Pi‐hole Ad Blocker ‐ a device that allows you to block all of those annoying advertisements on the internet. Since Pi‐hole works at the DNS level, ads can be blocked on any device and even in apps. Kit contains  Pi Hole Box  1m Ethernet Cable ‐ Red  2.5A International Power Supply Unit  16GB SD card with Pi Hole software  HDMI cable Block Over 100,000 Ad‐serving Domains Known ad‐serving domains are pulled from third party sources and compiled into one list. Block Advertisements On Any Device Network‐level blocking you to block ads in non‐traditional placed such as mobile apps and smart TVs, regardless of hardware or OS. Improve Overall Network Performance Since ads are blocked before they are downloaded, your network will perform better. Reduce Cellular Data Usage Pair your Pi‐hole with a VPN for on‐the‐go ad‐blocking and save on data costs. Monitor Performance And Statistics The Web interface shows how many ads were blocked, a query log, and more. API Utilize Pi‐hole’s API in your scripting or programming projects. { "domains_being_blocked":243038, "dns_queries_today":2385, "ads_blocked_today":414, "ads_percentage_today":17.35849, "unique_domains":429, "queries_forwarded":1537, "queries_cached":434, "clients_ever_seen":5, "unique_clients":5, "status":"enabled" } Use Pi‐Hole As Your DNS Server Configure your router’s DHCP options to force clients to use Pi‐hole as their DNS server, or manually configure each device to use the Pi‐hole as their DNS server. If your router doesn’t let you change these settings, you can use Pi‐hole’s built in DHCP server to achieve the same effect. Block Ads Everywhere Since Pi‐hole works at the DNS level, ads can be blocked on any device and even in apps.                                              https://uk.pi‐supply.com/products/pi‐hole‐kit‐network‐wide‐ad‐blocker 6‐26‐18
PIS-0797 价格&库存
很抱歉,暂时无法提供与“PIS-0797”相匹配的价格&库存,您可以联系我们找货
