PIS-0622
PIS-0622
    PISUPPLY
    PINKPI STAKEBOX
PIS-0622 数据手册
  PinkPi StakeBox StakeBox and Pinkcoin?bring?you a one of a kind device.?PinkPi?‐ a custom designed,?custom‐made?investment machine The PinkPi is an easy to use and easy to set up device that brings the world?s most advanced blockchain based charity, Pinkcoin, into your home. A simple plug and play unit running on the Raspberry Pi 3, that will get you staking Pink in no time at all. Easily track your information from a clean and easy to understand user interface. Running on practically no energy and small enough to fit practically anywhere, you can help keep the Pink network strong and secure while also earning rewards over time. The new wave of cryptocurrency hardware devices is here, and it?s running on Pink. The PinkPi is one of the first native crypto hardware devices built with mass adoption in mind. This kit includes everything you need to get a professional level staking machine up and running in no time at all and be able to enjoy it for years to come at an affordable price that gives everyone the ability of earn crypto rewards without having to invest in expensive and quickly outdated machines.?You can check your individual staking APR by visiting?https://getstarted.with.pink/faq/ Staking Pinkcoin is the process of securing the network with your coin weight, which in turn rewards you with newly minted Pinkcoin. Set Up Process: Step 1: Plug in device Step 2: Run setup via the mobile app.? ? ? ? ? ? ? ‐ Setup Internet ? ? ? ? ? ? ‐ Deposit Coins Step 3: Receive notifications every time your Raspberry Pi stakes a block.?? What's Inside  Raspberry Pi 3 Model B  PinkPi?Case  2.5A International Power Supply Unit  16GB SD card with?PinkPi software  HDMI cable Raspberry Pi 3 Specifications  Processor o Broadcom BCM2387 chipset o 1.2GHz Quad‐Core ARM Cortex‐A53 o  802.11 b/g/n Wireless LAN and Bluetooth 4.1 (Bluetooth Classic and LE) GPU o o  o  o  o  o Dual Core VideoCore IV? Multimedia Co‐Processor. Provides Open GL ES 2.0, hardware‐accelerated OpenVG, and 1080p30 H.264 high‐profile?decode Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and?DMA infrastructure Memory 1GB LPDDR2 Operating System Boots from Micro SD card, running a version of the Linux operating system or?Windows 10 IoT Dimensions 85 x 56 x 17mm Power Micro USB socket 5V1, 2.5A Learn More   For more information on Pink the charity, and Pink the currency, please visit:?https://getstarted.with.pink/ *staking interest depends on the specific cryptocurrency and other conditions and is not guaranteed by StakeBox                                        https://uk.pi‐supply.com/products/pinkpi‐stakebox 6‐26‐18
PIS-0622 价格&库存
很抱歉,暂时无法提供与“PIS-0622”相匹配的价格&库存,您可以联系我们找货
