PIS-0134
PIS-0134
    PISUPPLY
    LITTLEBITS ARDUINO CODING KIT
PIS-0134 数据手册
    littleBits Arduino Coding Kit SKU: PIS-0134 YOU BRING THE CODE. WE’LL BRING THE ELECTRONICS – This kit contains 8 of our favorite prototyping modules. It’s everything you need to get started with electronics and programming. Description YOU BRING THE CODE. WE’LL BRING THE ELECTRONICS. This kit contains 8 of our favorite prototyping modules. It’s everything you need to get started with electronics and programming. Make your own Etch-a-Sketch™! Program a visual display! littleBits will walk you through the basics using the Arduino programming environment, without the breadboarding, soldering or wiring normally required. Perfect for hackers, designers, makers and tinkerers of all levels.      Includes everything you need to get started (battery + power included!) right out of the box Build with 8 Getting Started sketches, including a DIY Etch-a-Sketch™, Mouse Control and hundreds more from Arduino’s community! Communicate with software (Processing, MaxMSP, Flash etc…) Snap modules easily to 3 inputs and 3 outputs on the Arduino module, as well as additional I/O for advanced hardware interaction Access to community support from Arduino AND littleBits The Arduino module is also available individually here . Check out our Tips + Tricks or our forum for more ideas on using Arduino! Additional information WEIGHT 0.4 kg        https://www.pi‐supply.com/product/littlebits‐arduino‐coding‐kit/ 1‐29‐18
PIS-0134 价格&库存
很抱歉,暂时无法提供与“PIS-0134”相匹配的价格&库存,您可以联系我们找货
