Flick Large – Standalone 3D Tracking
and Gesture Breakout
SKU: PIS-0554
Flick Large is a standalone 3D tracking and gesture breakout that’s compatible with Raspberry Pi,
BeagleBone, Arduino, Genuino, or any I2C enabled device.
Description
We’re currently out of stock. Please visit RS Components to
purchase Flick Large
Swipe, tap or flick your wrist to control your I2C device with the Flick Large board.
Flick Large is a 3D tracking and gesture board that lets you control your I2C enabled devices as if by
magic!
Flick uses technology that enables the PCB to detect your gestures from up to 15cm away in 3D
space. Draw a circle, swipe your hand – Flick will track it.
Integrate Flick into your I2C project to give you multiple ways of controlling it. Using the near field
gesture technology, you’re able to hide your project behind non conductive material (wood/acrylic)
and still use Flick (please note however that mounting it in this way may reduce the sensor range).
Plug and play functionality allows you to get up and running within minutes. Use our software
libraries (complete with one line installer) to fully explore what you can do with Flick. Control your
computer, TV, music system and more all with a Flick of the wrist!
Features
Compatible with Raspberry Pi, BeagleBone, Arduino, Genuino or any I2C enabled device
3D tracking
Gesture sensing up to 15cm
Touch and Tap sensing
Communicates with the Raspberry Pi via I2C
Full software libraries (fully open-source code)
No soldering required
Dimensions: 14.8 cm x 10.4cm x 0.5cm
Level shifting chip to enable board to work with 3V3 or 5V0 power and logic
Orange/green dual colour LED on board
One line installer
Fully CE and FCC tested and approved
Kit Contents
1 Flick Large
1 Jumper cable female to female
1 Jumper cable female to male
3 Stickers
2 Info cards
Software and Setup Guide
Software for the Flick boards is available here on GitHub
Follow this guide to set up your Flick Large board and case
Technical Details
Chip: MGC3130 3D Tracking and Gesture Controller
Detection range: 0 to 15 cm in ideal circumstances
Temperature Range: -20℃ to +85℃
Position Rate: 200 positions/sec
Spatial Resolution: up to 150 dpi
Proximity and Touch Sensing
Flick Large has a red/green dual colour LED that can be driven using pins LED1 and LED2
Flick Large has level shifting on board so can work with any microcontroller with either 5V or 3V3
power and data signals
Compatible with the Hillstar Development Kit over USB on PC in order to use with a computer or to
program new firmware onto the board.
Available gestures: Swipe (east to west, west to east, north to south, south to north), tap and double
tap (center, east, west, north, south), airwheel (clockwise, anti-clockwise) and touch (center, east,
west, north, south)
Works even through the Flick Large case
No detection blind spots
Low–power design
Explore the entire Flick range
We have Flick boards for the Raspberry Pi Zero and main Raspberry Pi boards
Additional information
WEIGHT
0.13 kg
DIMENSIONS
20.5 x 12.5 x 2.5 cm
https://www.pi-supply.com/product/flick-large-standalone-3d-tracking-gesture-breakout/ 2/5/18
很抱歉,暂时无法提供与“PIS-0554”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+381.4360450+49.32062
