PIS-0559
PIS-0559
    PISUPPLY
    JUSTBOOM DAC ZERO KIT
PIS-0559 数据手册
      JustBoom DAC Zero Kit SKU: PIS-0559   The JustBoom DAC Zero kit is a fully plug-and-play package that is simple to setup and use. Plug in the power cable, connect the kit to a set of powered speakers or an audio amplifier, set up the JustBoom Player software, and start enjoying lossless audio.  Description The JustBoom DAC Zero kit is a fully plug-and-play package that is simple to setup and use. No soldering or technical knowledge is needed to get up and running. Plug in the power cable, connect the kit to a set of powered speakers or an audio amplifier,and set up the JustBoom Player software. You can then be up and running quickly, enjoying flawless high quality audio playback within minutes of unboxing.                     Use Cases Streaming (either from cloud or network storage) high-definition audio player Multi-room audio player Media centre / set-top box living room entertainment system Shop floor / elevator / background music audio player High quality audio player with local storage Desktop high definition audio player with amplified headphone output Kit includes: Raspberry Pi Zero W (comes with a pre soldered header) JustBoom DAC Zero pHAT JustBoom DAC Zero pHAT case Official Raspberry Pi Power Supply JustBoom Player Software 3.5mm to 3.5mm Audio Cable Features Full high quality audio – 384kHz / 32bit Line-level RCA and headphone amplified 3.5mm jack outputs Plug and play compatibility for ease of use Hardware and software volume control from your Raspberry Pi No soldering required Powered by the Raspberry Pi GPIO header Full driver support in Raspbian / NOOBS Compatible with OSMC / Max2Play / RuneAudio / Volumio / Moode / PiCorePlayer / PiMusicBox / OpenELEC and others   Additional information WEIGHT 0.35 kg DIMENSIONS 9 x 17 x 14 cm                                       https://www.pi‐supply.com/product/justboom‐dac‐zero‐kit/2/9/18
PIS-0559 价格&库存
很抱歉,暂时无法提供与“PIS-0559”相匹配的价格&库存,您可以联系我们找货
