PIS-0569
PIS-0569
    PISUPPLY
    电池
    太阳能电池 6 W
PIS-0569 数据手册
      PiJuice Solar Panel – 6 Watt SKU: PIS-0569 This solar panel is designed for use with the PiJuice power platform for your Raspberry Pi. It has a regulated 5 volt USB output attached to the internal smart-power chip so it also works with your smartphone, tablet, laptop, camera, audio players and more. Description The PiJuice 6 Watt Solar panel is the ideal way to charge and/or power your PiJuice HATand Raspberry Pi for free when you’re in a sunny location. By using a solar panel and PiJuice, containing our revolutionary PiAnywhere technology, you can truly take your Raspberry Pi off the grid! Features          Highly portable – a compact 6 watt panel that folds down and secures with magnets into a super compact size. Easy to pack up and go Easily mountable – metal eye-holes in each corner (4 total) allow easy attachment to backpacks, trees, or tents Has a useful velcro storage pouch for storing any essential items Storage pouch cover also acts as a velcro / frabric “kick stand” for the solar panel in order to stand it up on a bench / table for maximum versatility Lightweight – The panel weighs only 320 grams Water resistant up to IPX4 rating Incredibly durable stitching and construction One Regulated 5v/1A USB output – it works with your PiJuice, smartphones, tablets, audio players and more! Features SunPower solar panels which provide industry-leading solar conversion efficiency Technical Information            Solar panel – 5.5 volts / 6 watts Regulated Max output – 5 volts / 5 watts Single USB max output – 5 watts Built in smart-power chip Boxed dimensions – 17.3 x 17.7 x 3.5cm Unboxed, folded dimensions – 16.3 x 15.6 x 2.5cm Unboxed, unfolded dimensions – 32.8 x 15.6 x 2.4cm Boxed weight – 420g Unboxed weight – 320g Country of origin – China CE and FCC tested What’s inside    PiJuice Solar Panel – 6 Watt USB to microUSB Cable User Manual Additional information WEIGHT 0.32 kg DIMENSIONS 17.5 x 17.5 x 3.5 cm        https://www.pi‐supply.com/product/pijuice‐solar‐panel‐6‐watt/1‐29‐18
PIS-0569 价格&库存
很抱歉,暂时无法提供与“PIS-0569”相匹配的价格&库存,您可以联系我们找货
PIS-0569
    • 1+603.028361+78.01782
    库存:9
