PIS-0570
PIS-0570
    PISUPPLY
    电池
    太阳能电池 12 W
PIS-0570 数据手册
        PiJuice Solar Panel – 12 Watt SKU: PIS-0570 This solar panel is designed for use with the PiJuice power platform for your Raspberry Pi. It has two regulated 5 volt USB outputs attached to the internal smart-power chip so it also works with your smartphone, tablet, laptop, camera, audio players and more. You can even charge two devices at once! Description The PiJuice 12 Watt Solar panel is the ideal way to charge and/or power your PiJuice HATand Raspberry Pi for free when you’re in a sunny location. By using a solar panel and PiJuice, containing our revolutionary PiAnywhere technology, you can truly take your Raspberry Pi off the grid! Features         Highly portable – a compact 12 watt panel that folds down and secures with magnets into a super compact size. Easy to pack up and go Easily mountable – one large metal eye-hole and fabric eyelet straps in each corner (one metal, 4 fabric for 5 total) allow easy attachment to backpacks, trees, or tents Has a useful zipping net storage pouch for storing any essential items Lightweight – The panel weighs only 390 grams Water resistant up to IPX4 rating Incredibly durable stitching and construction Two Regulated 5v/2A USB outputs – it works with your PiJuice, smartphones, tablets, audio players and more! Features SunPower solar panels which provide industry-leading solar conversion efficiency Technical Information            Solar panel – 5.5 volts / 12 watts Regulated Max output – 5 volts / 10 watts Single USB max output – 10 watts (there are two on board which can be used simultaneously but max total output will be 10 watts overall) Built in smart-power chip Boxed dimensions – 28.5 x 16.6 x 4.2cm Unboxed, folded dimensions – 26 x 15.5 x 3cm Unboxed, unfolded dimensions – 38 x 26 x 2.5cm Boxed weight – 485g Unboxed weight – 390g Country of origin – China CE and FCC tested What’s inside    PiJuice Solar Panel – 12 Watt USB to microUSB Cable User Manual Additional information WEIGHT 0.479 kg DIMENSIONS 29 x 19 x 4 cm        https://www.pi‐supply.com/product/pijuice‐solar‐panel‐12‐watt/ 1‐30‐18
PIS-0570 价格&库存
很抱歉,暂时无法提供与“PIS-0570”相匹配的价格&库存,您可以联系我们找货
PIS-0570
    • 1+958.061221+123.96174
    • 10+851.6426310+110.19244
    库存:16
