PiJuice Solar Panel – 40 Watt
SKU: PIS-0572
This solar panel is designed for use with the PiJuice power platform for your Raspberry Pi. It has two
regulated 5 volt USB outputs as well as a regulated 19 volt DC jack output attached to the internal
smart-power chip so it also works with your smartphone, tablet, laptop, camera, audio players and
more. You can even charge multiple devices at once!
Description
The PiJuice 40 Watt Solar panel is the ideal way to charge and/or power your PiJuice HATand
Raspberry Pi for free when you’re in a sunny location. By using a solar panel and PiJuice, containing
our revolutionary PiAnywhere technology, you can truly take your Raspberry Pi off the grid!
Features
Highly portable – a large 40 watt panel that folds down and velcros into a super compact size. Easy
to pack up and go
Easily mountable – three metal eye-holes on each edge (6 total) allow easy attachment to backpacks,
trees, or tents
Has a useful velcro storage pouch for storing any essential items
Lightweight – The panel weighs only 900 grams
Water resistant up to IPX4 rating
Incredibly durable stitching and construction
Two Regulated 5v/2.4A USB outputs and a 19 volt DC jack – it works with your PiJuice, smartphones,
tablets, audio players and more!
Features SunPower solar panels which provide industry-leading solar conversion efficiency
Technical Information
Solar panel – 6.5 volts / 40 watts
Regulated Max output – 5 volts / 35 watts
Single USB max output – 12 watts (there are two on board which can be used simultaneously)
Includes 19 volt DC jack output
Built in smart-power chip
Boxed dimensions – 34.7 x 17.1 x 5.1cm
Unboxed, folded dimensions – 33 x 16 x 4cm
Unboxed, unfolded dimensions – 70.5 x 65 x 1.8cm
Boxed weight – 1.1kg
Unboxed weight – 0.9kg
Country of origin – China
CE and FCC tested
What’s inside
USB to microUSB Cable
User Manual
Additional information
WEIGHT
1.056 kg
DIMENSIONS
34 x 21 x 5.5 cm
https://www.pi‐supply.com/product/pijuice‐solar‐panel‐40‐watt/1‐30‐18
很抱歉,暂时无法提供与“PIS-0572”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1809.981401+234.45590
- 10+1707.0895910+221.12781
