PIS-0924
PIS-0924
    PISUPPLY
    BATTBORG PI BATTERY POWER BOARD
PIS-0924 数据手册
    BattBorg ‐ Pi Battery Power Board (Soldered Kit) The BattBorg is a plug and play power converter for your Raspberry Pi which allows you to power the Raspberry Pi with batteries! It's great for robot projects, or where you need to leave you Pi unmanned for extended periods without a wired power source (outside sensor projects etc.) he BattBorg uses a highly efficient (~90%) OKI78SR DCDC converter which has a maximum 1.5A output and, due to it's efficiency, requires no heatsink. It will work with most batteries/battery packs that are between 7‐36V so it's great for 12V car batteries, 8xAA battery packs, and so on. BattBorg comes in several different kits. This purchase is for the Full Soldered Kit, which includes a fully assembled BattBorg, one 8 x AA battery holder, and the cables to hook it all up. Just add your Raspberry Pi, and batteries, and you're ready to roll! BattBorg Features:  Fully Assembled Kit Includes: o Assembled & Soldered BattBorg PCB o 8 x AA Battery Pack o 3 Pin Cable M/F Cable o PP3 Connector Cable  Mounting Pillar & Screw 5V 1.5A Max Output  ~90% Efficient  Compatible with battery packs (or batteries) between 7V ‐ 36V  Plugs into GPIO Pins 2, 4 & 6  Up to 14 Hours Run‐Time @ 15% Load (8 x AA Batteries)  Compatible with Model A, B, A+, B+, 2, 3, Zero, ZeroW o                   https://uk.pi‐supply.com/products/battborg‐pi‐battery‐power‐board‐soldered‐kit 7‐27‐18
PIS-0924 价格&库存
很抱歉,暂时无法提供与“PIS-0924”相匹配的价格&库存,您可以联系我们找货
