PIS-0930
PIS-0930
    PISUPPLY
    直流电机 齿轮电机 149 RPM 6VDC
PIS-0930 数据手册
        PiBorg Motor 6V 180RPM ‐ 20mm 6V 180RPM, 20mm Diameter DC Motor! Built to PiBorgspecification and specially made for awesome robots! PiBorg motors comes with wires pre‐soldered, so perfect for connecting straight to your project! This motor features a 3mm diameter shaft so fits a 3mm hub, and can be mounted to a chassis using our Advanced Motor Bracket Mount! Please Note. This purchase is for the motor only. Technical Specification  Part No. P20UK6  Voltage: 6V  Gearbox Reduction Ratio: 33  No Load Speed (RPM): 180  Rated Speed (RPM): 149  Rated Torque (kg.cm): 0.13  Rated Current (A): 0.087  Shaft Diameter: 3mm  Shaft Length: 8mm  Motor Diameter: 20mm  Motor Length: 40mm                            https://uk.pi‐supply.com/products/piborg‐motor‐6v‐180rpm‐20mm 7‐26‐18
PIS-0930 价格&库存
很抱歉,暂时无法提供与“PIS-0930”相匹配的价格&库存,您可以联系我们找货
PIS-0930
  • 1+203.845201+26.37049
  • 5+187.338625+24.23511
  • 10+180.6384210+23.36834
  • 25+172.1560625+22.27102
库存:30
