PIS-0932
PIS-0932
    PISUPPLY
    直流电机 齿轮电机 480 RPM 12VDC
PIS-0932 数据手册
  PiBorg Motor 12V 590RPM ‐ 28mm 12V 590RPM, 28mm Diameter DC Motor! Built to PiBorg specification and specially made for awesome robots! PiBorg motors comes with wires pre‐soldered, so perfect for connecting straight to your project! This motor features a 4mm diameter shaft so fits a 4mm hub, and can be mounted to a chassis using our Advanced Motor Bracket Mount! Please Note. This purchase is for the motor only. Technical Specification  Part No. P28UK12  Voltage: 12V  Gearbox Reduction Ratio: 11  No Load Speed (RPM): 590  Rated Speed (RPM): 480  Rated Torque (kg.cm): 0.4  Rated Current (A): 0.497  Shaft Diameter: 4mm  Shaft Length: 12mm  Motor Diameter: 28mm  Motor Length: 59mm                       https://uk.pi‐supply.com/products/piborg‐motor‐12v‐590rpm‐28mm 7‐26‐18
PIS-0932 价格&库存
很抱歉,暂时无法提供与“PIS-0932”相匹配的价格&库存,您可以联系我们找货
PIS-0932
  • 1+253.767371+32.83159
  • 5+233.242695+30.17617
  • 10+224.9036810+29.09730
库存:15
