PIS-0933
PIS-0933
    PISUPPLY
    直流电机 齿轮电机 205 RPM 12VDC
PIS-0933 数据手册
  PiBorg Motor 12V 300RPM ‐ 37mm (MonsterBorg) 12V 300RPM, 37mm Diameter DC Motor! Built to PiBorg specification and specially made for awesome robots! PiBorg motors comes with wires pre‐soldered, so perfect for connecting straight to your project! This motor features a 6mm diameter shaft so fits a 6mm hub, and can be mounted to a chassis using our Large Advanced Motor Bracket Mount! Please Note. This purchase is for the motor only. These are the same motors that power our MonsterBorg kits. Technical Specification  Part No. P37UK12  Voltage: 12V  Gearbox Reduction Ratio: 17.4  No Load Speed (RPM): 300  Rated Speed (RPM): 205  Rated Torque (kg.cm): 1.02  Rated Current (A): 0.716  Shaft Diameter: 6mm  Shaft Length: 14mm  Motor Diameter: 37mm  Motor Length: 57mm             https://uk.pi‐supply.com/products/piborg‐motor‐12v‐300rpm‐37mm‐monsterborg 7‐26‐18
PIS-0933 价格&库存
很抱歉,暂时无法提供与“PIS-0933”相匹配的价格&库存,您可以联系我们找货
PIS-0933
  • 1+46.758041+6.04816
库存:186
PIS-0933
  • 2+47.573592+6.15365
库存:186
