PIS-0942
PIS-0942
    PISUPPLY
    DIDDYBORG V2 ROBOT KIT RED EDITI
PIS-0942 数据手册
      DiddyBorg V2 Robot Kit ‐ Red Edition Our most popular Raspberry Pi robot kit DiddyBorg is back with faster motors and a newly designed chassis! Red Edition comes with six upgraded 28mm 590rpm metal geared motors. Red ones really do go faster! Description The idea remains the same, a 6 wheeled high‐torque robotics platform, but give everyone the ability to add lots of extra functionality and get your robot to perform a wide range of tasks. Want to detect objects in your DiddyBorg's path? Add the ultrasonic mounts at the front and back. Need to use a servo to move a robotic arm? Mount them on the multifunction top and go! You could even add the Raspberry Pi touch screen and turn your robot into a touchscreen controlled turtle. A Raspberry Pi B+/2/3/3B+ and SD cardare required to complete your DiddyBorg v2, they are not included. DiddyBorg v2 optionally supports the Pi Camera, also not included. Specifications   Basic DiddyBorg v2 comes with:  Chassis: Laser cut 3mm Cast Acryllic PerspexTM in Purple now designed and cut at PiBorg.  Red edition comes with six upgraded 28mm 590rpm metal geared motors. Red ones really do go faster!  Our ThunderBorg 5A dual output motor controller including LED indicator, power regulator and PWM control.  On/Off switch.  Full build instructions.  Code library and example scripts. There are two additional styles of top available for the DiddyBorg v2:  The Multifunction Top with mounting holes for servos and adaptable mounting points for an additional Raspberry Pi 3, Raspberry Pi Zero or Zero W or the Arduino Uno.  The Touch Top which takes the Raspberry Pi 7" touch screen. These can be used in addition to the basic kit in a number of combinations! We also have a sensor mounting kitwhich includes mounts for 4x ultrasonics and a second pi camera.     https://uk.pi‐supply.com/products/diddyborg‐v2‐robot‐kit‐red‐edition7‐31‐18
PIS-0942 价格&库存
很抱歉,暂时无法提供与“PIS-0942”相匹配的价格&库存,您可以联系我们找货
