iFixit Mahi Driver Kit ‐ 48 Bit Driver Kit
Features
The Mahi Driver Kit includes iFixit’s 1/4"" aluminum screwdriver handle with
magnetic bit socket, knurled grip, and swivel top—plus 48 driver bits.
Spanners, Squares, and Splines—oh my! In addition to standard Phillips and
Flathead, this bit kit includes all the 1/4"" form factor bits you’ll need to handle the
toughest and torque‐iest fasteners in any home or shop project.
All our next‐gen bit kits have been re‐engineered for maximum utility. The bit kit lid
is held in place with magnets to increase product lifespan (no more broken hinges
or clasps) and also mounts to the back of the bit kit case to keep it out of the way
while you do your work. Or, if you need help keeping your screws and parts
organized, use the lid’s integrated sorting tray.
Toolkit Includes
Easy‐to‐Open Magnetized Case
Lid with Built‐in Sorting Tray
1/4"" Aluminum Bit Driver
1/4"" Screwdriver Bits
Phillips ‐ 0, 1, 2, 3
Flathead ‐ 4, 6, 8 mm
Hex Security ‐ 4, 5, 6, 7, 8 mm
Hex Security SAE ‐ 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
Pozidriv ‐ PZ1, PZ2, PZ3
Spanner ‐ 4, 6, 8, 10, 12
Square ‐ 2, 3
Spline ‐ M5, M6, M8
Torx Security ‐ TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
Tri‐wing 1, 2, 3, 4
Clutch 1, 2, 3
Schrader Valve
1/4"" Driver to 1/4"" Socket
Specifications
Bit Material: 6150 Steel
Driver Material: Anodized Aluminum
Case Material: ABS
Foam: EVA
https://uk.pi‐supply.com/products/mahi‐kit‐48‐screwdriver‐kit 8‐29‐18
很抱歉,暂时无法提供与“PIS-0948”相匹配的价格&库存,您可以联系我们找货
