PIS-0949
PIS-0949
    PISUPPLY
    IFIXIT MANTA DRIVER KIT - 112 BI
PIS-0949 数据手册
  iFixit Manta Driver Kit ‐ 112 Bit Driver Kit The Manta Driver Kit includes iFixit's 1/4" Drive and 4mm Drive premium aluminium screwdriver handles with magnetic bit sockets, knurled grips, and swivel tops plus 112 precision driver bits. This kit includes our widest assortment of bits, complete with every driver head you’ll need to tackle any repair/DIY project. Features This kit includes our widest assortment of bits, complete with every driver head you’ll need to tackle any repair or DIY project. It includes standard bits like Phillips and Flathead in a full range of sizes to handle everything from precision electronics repair to home DIY projects. And it wouldn’t be an iFixit bit kit if it didn’t include all the exotic bits from Pentalobes for Apple iPhone and MacBook repair to Gamebits for your vintage Nintendo consoles. All our next‐gen bit kits have been re‐engineered for maximum utility. The bit kit lid is held in place with magnets to increase product lifespan (no more broken hinges or clasps) and also mounts to the back of the bit kit case to keep it out of the way while you do your work. Or, if you need help keeping your screws and parts organized, use the lid’s integrated sorting tray. And our 4 mm bits have been redesigned with a longer neck for a deeper and more precise reach. Toolkit Includes  Easy‐to‐Open Magnetized Case  Lid with Built‐in Sorting Tray  4 mm Aluminum Bit Driver  1/4" Aluminum Bit Driver  4 mm Screwdriver Bits o Phillips ‐ 000, 00, 0 o Flathead ‐ 1, 1.5, 2, 2.5, 3, 3.5 mm o Torx ‐ T2, T3, T4, T5 o Torx Security ‐ TR6, TR7, TR8 o Pentalobe ‐ P2, P5, P6 o JIS ‐ 000, 00, 0, 1 o Hex ‐ 0.7, 0.9, 1.3, 1.5 mm o Hex Security ‐ 2, 2.5, 3, 3.5 mm o Tri‐point ‐ Y000, Y00, Y0, Y1 o Nut driver ‐ 2.5, 3, 3.5, 4, 4.5, 5, 5.5 mm o Gamebit ‐ 3.8, 4.5 mm o Spanner ‐ 4, 6 o Triangle ‐ 2, 2.2, 2.6, 3 mm o Oval Bit o iPhone Standoff Bit o Sim Eject Bit  Magnetic Pickup Bit 1/4" Screwdriver Bits o Phillips ‐ 1, 2, 3 o Flathead ‐ 4, 5, 6, 7, 8 mm o vHex Security ‐ 4, 5, 6, 7, 8 mm o Hex Security SAE ‐ 1/8, 9/64, 5/32, 3/16, 7/32, 1/4 o Pozidriv ‐ PZ0, PZ1, PZ2, PZ3 o Torq‐set ‐ 6, 8, 10 o Spanner ‐ 8, 10, 12 o Square ‐ 0, 1, 2, 3 o Spline ‐ M5, M6, M8 o Torx Security ‐ TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40 o Tri‐wing 1, 2, 3, 4 o Clutch 1, 2, 3 o Schrader Valve o Hook Drive o 1/4" to 4 mm Adapter o 1/4" Driver to 1/4" Socket o 1/4" Driver to 3/8" Socket o 1/4" Socket to 1/4" Driver o Specifications  Bit Metal: 6150 Steel  Driver Material: Anodized Aluminum  Case Material: ABS  Foam: EVA                       https://uk.pi‐supply.com/products/manta‐driver‐kit‐112‐bit‐driver‐kit 8‐29‐18
PIS-0949 价格&库存
很抱歉,暂时无法提供与“PIS-0949”相匹配的价格&库存,您可以联系我们找货
PIS-0949
    • 10+948.4003910+123.19240
