PIS-0952
PIS-0952
    PISUPPLY
    IFIXIT PRO TECH SCREWDRIVER SET
PIS-0952 数据手册
    iFixit Pro Tech Screwdriver Set Standard Features Level up your workbench with iFixit's new line of Pro Tech Screwdrivers. These fixed blade screwdrivers each feature an ergonomic, knurled, rubberized handle with swivel top. Each precision screwdriver tip is coated with black oxide, so it hangs on to tiny screws with a steel grip. The screwdriver set case matches the style of our 64 Bit Driver Kit. The lid is held in place magnetically and can be used as a sorting tray or stand while you work on your project. These drivers are engineered by iFixit, manufactured in Germany, and backed by iFixit's Lifetime Warranty. Screwdriver Set Includes:  Phillips #000 Screwdriver  Phillips #00 Screwdriver  Phillips #0 Screwdriver  Phillips #1 Screwdriver  Flathead 3/32" or 2.5 mm Screwdriver We have three different screwdriver sets, each featuring different head styles. Check out our Specialty Set featuring Torx, Pentalobe, and Tri‐point drivers and our Torx Security Set.                       https://uk.pi‐supply.com/products/pro‐tech‐screwdriver‐set‐standard  8‐29‐18
PIS-0952 价格&库存
很抱歉,暂时无法提供与“PIS-0952”相匹配的价格&库存,您可以联系我们找货
