PIS-0966
PIS-0966
    PISUPPLY
    IFIXIT IMAC OPENING WHEEL
PIS-0966 数据手册
    iFixit iMac Opening Wheel It's like opening an iMac pizza   The unique design of the Late 2012 iMacs require the cutting of the foam tape on the display to get inside. This tool comes in two parts:  The handle is made of tough, laser‐cut Nylon and easily accommodates the cutting wheel while providing plenty of grip.  The cutting wheel is specifically designed to slip in the hair‐thin gap between the display and the aluminum frame, then easily cut the foam holding the two pieces together.                                        https://uk.pi‐supply.com/products/imac‐opening‐wheel 8‐29‐18
PIS-0966
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1x3.6mm。
PIS-0966 价格&库存
很抱歉,暂时无法提供与“PIS-0966”相匹配的价格&库存,您可以联系我们找货
