PIS-1016
PIS-1016
    PISUPPLY
    - 915MHz 评估板
PIS-1016 数据手册
        RAK831 Pilot Gateway Professional Demonstration Setup The RAK831 Pilot Gateway is a device that consists of a Raspberry Pi 3, a RAK831 LoRa Concentrator, converter board with GPS module and a heat sink on top of the RAK831 module . Built with an aluminium housing, the can be used as a ready to use LoRaWAN Gateway that can be connected to a LoRaWAN server. The RAK831 Pilot Gateway is meant to be used as a demonstration system for the LoRaWAN network system. It is not designed to be a fully featured outdoor gateway. Please operate the Lite gateway only indoors and in combination with the delivered power supply and antenna. Basic system concept for the LoRaWAN system The RAK831 Pilot Gateway is the central hardware solution for all LoRa based radio communication. It receives and transmits radio messages. Processing of the radio messages as well as the protocol related tasks is done by the embedded host system (Raspberry Pi). Received and processed radio messages are being sent to a LoRaWAN server. The concrete segmentation of the protocol related tasks is outside the scope of this document. The pre‐installed github repositories are:  ”lora_gateway”  ”packet_forwarder” Both repositories have been installed on the folder /home/pi/github. Hardware The RAK831 Pilot Gateway consists of a Raspberry Pi 3, a RAK831 LoRa Concentrator and a converter board with GPS for routing the signals between the Raspberry Pi and the RAPK831. More information on the RAK831 can be found here Comes with  RAK831 Pilot Gateway and LoRa Antenna  Raspberry Pi 3  DC‐5v Power Supply x 1  GPS Antenna x 1  DC(5.5 x 2.1) to Micro USB x 1 Kit        https://uk.pi‐supply.com/products/rak831‐pilot‐gateway‐professional‐demonstration‐setup 9‐17‐18
PIS-1016 价格&库存
很抱歉,暂时无法提供与“PIS-1016”相匹配的价格&库存,您可以联系我们找货
