PIS-1027
PIS-1027
    PISUPPLY
    RAK811 BREAKOUT BOARD 915MHZ
PIS-1027 数据手册
          RAK811 Breakout Board with SMA + IPX connectors Simple breakout board for using the RAK811/811‐N module standalone or attached to any UART device. What is it? It’s a simple breakout board which has a 3.3V regulator, SMA, and IPX mounting place, SWD programming header and everything else as header output. You can used this to test your RAK811 module without any hassle. Why did you make it? There’s currently just the Wisnode Arduino shield thing for the RAK811. If you wanted a simple thing which just takes the RAK811 without a big clunky and unneeded PCB around it. What makes it special? It’s small and open source!        https://uk.pi‐supply.com/products/rak811‐breakout‐board‐sma‐ipx‐connectors 10‐14‐18
PIS-1027 价格&库存
很抱歉,暂时无法提供与“PIS-1027”相匹配的价格&库存,您可以联系我们找货
