PIS-1037
PIS-1037
    PISUPPLY
    RAK833-EVB MINI PCIE LORA GATEWA
PIS-1037 数据手册
          RAK833‐EVB Mini PCIe LoRa Gateway Concentrator Module and Router AP Evaluation Kit Description The RAKwireless RAK8333‐EVB kit is specifically designed for PCIe LoRa Gateways RAK833 which can be quickly used and easily tested by developers. RAK833‐EVB kit includes:  RAK833 LoRa Gateway  RAK634 (Base on MT7628N wireless AP Module)  2 USB Ports  1 Power Interface  1 TF card slot  1 Reset button  1 SMA antenna interface  1 WAN and LAN interface The physical size is 90mm x 80mm x 18mm. What do I get?  RAK833‐EVB Kit  Ethernet Cable  Jumping Cap  Bar Antenna  LoRa Antenna  DC‐12V Power Supply  Micro USB cable Specification   RAK833 PCIe LoRa Gateway  RAK833‐SPI: Only supports SPI interface  RAK833‐SPI/USB: Supports both SPI & USB interface Mini PCIs LoRa Gateway Module ‐ Based on SX1301 and FT2232H  Frequency band 868MHz & 915MHz  Standard Mini PCI‐s form factor with 52 Pin  Voltage of Mini PCI‐e is 3.3v which is compatible with 3G/LTE card of mini PCIs type  Interfaces USB & SPI  SX1301 base band processor emulates 49 x LoRa demodulators 10 parallel demodulation paths  Module build in FT2232H to convert SPI interface of SX1301 to USB2.0 RAK634 AP Module  Operating Frequencies: 2.4 to 2.4835GHz  IEEE Standards: IEEE 802.11b/g/n  Wireless data rate can reach up to 300Mbps  Connect to the external antenna through i‐pex connector or layout.  Power supply: 3.3v =0.2V  16MB Flash, 40MHz XTAL, 128MB DDR2                                    https://uk.pi‐supply.com/products/rak833‐evb‐mini‐pcie‐lora‐gateway‐concentrator‐module‐router‐ap‐evaluation‐kit 10‐14‐18
PIS-1037 价格&库存
很抱歉,暂时无法提供与“PIS-1037”相匹配的价格&库存,您可以联系我们找货
