LX200V30 HomePlug AV power line
module ‐ super high speed up to 500Mbps
Network Adapter (QCA7420 based) with
power line / twisted pair / Ethernet
interface
LX200V30 is a new type of data transmission product based on OFDM (Orthogonal
Frequency Division Multiplexing). The maximum transmission rate of power lines
can reach 500Mbps, and standard Ethernet ports, as well as the two interfaces of
twisted pair and coaxial cable are provided.
Support 128‐bit AES encryption, communicate via frequency band of 2~30MHz, and
the existing CATV signal or wired broadcasting is not affected.
It can be put into work after the wiring is completed without any user configuration.
This will advance the product's time‐to‐market and increase the flexibility of
product functionality.
Features
Media (multiple transmission media are supported)
o
Power line: Complete the last 300 meters of IP access.
o
Twisted pair: Complete the last 600 meters of IP access.
Coaxial cable: Complete the last 2,000 meters of IP access.
Speed
o
Transmission rate can reach up to 500Mbps;
o
Smooth transmission of IPTV, HDTV and other audio and video signal.
Reliable
o
128 bit AES encryption is supported to protect network communication security.
o
o
Communicate via frequency band of 2‐30MHz, and the existing CATV signal or wired
Follow the IEEE 1901 and HomePlug AV standard, and a maximum of 4 modules can
be carried. If to communicate with LX200V10, one LX200V10 supports up to 63
LX200V30 to connect the network.
Simple
o
It can be used after the completion of cable‐connecting without user configuration.
o
o
o
There is special management configuration software, making it easy for network
division and networking.
Modular design makes it easy to integrate into customer products
Applications
LX200V30 can be widely used in the industry and smart home systems, and is a
good complement to Ethernet and WIFI, so as to achieve the purpose of hybrid
networking and seamless networking. At present, it plays a great role in smart
home, monitoring, medical equipment networking and other scenarios.
LX200V30 Module
As shown below, LX200V30 module is small in size which is 40x30mm. It can be
used with WISPLC PRO backplane to transmit at a physical layer rate of up to
500Mbps. It is easy to connect with a product in design through the network cable,
which will speed up the time‐to‐market and the flexibility of product functionality.
https://uk.pi‐supply.com/products/lx200v30‐homeplug‐av‐power‐line‐module‐super‐high‐speed‐up‐to‐500mbps‐network‐adapter‐qca7420‐based‐with‐power‐line‐twisted‐pair‐ethernet‐interface 9‐14‐18
很抱歉,暂时无法提供与“PIS-1117”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15+517.8350115+67.12128
