PIS-0901
PIS-0901
    PISUPPLY
    RASPBERRY PI ZERO BCM2835 EVAL
PIS-0901 数据手册
      Pi Zero v1.3 with Colour Coded Soldered Header The Raspberry Pi Zero v1.3 is super low cost and smaller than the Raspberry Pi 3 and comes with a pre‐soldered colour coded header. This 40 pin 2x20 male header makes it easier for you to find the right pins.  Red = 5V  Yellow = 3V3  Black = GND  Blue = DNC (Reversed I2C)  Green = GPIO pins The Raspberry Pi Zero v1.3 now comes complete with a camera port. Using the new Raspberry Pi Zero Camera Adapter, you can now connect a Raspberry Pi camera to your Zero. HAT Compatibility Note The Pi Zero is fully compatible with all HAT breakout boards, as it features the same 40 Pin GPIO as the Raspberry Pi 2/B+/A+ Raspberry Pi Zero includes:  BCM2835 (same as Pi 1) but up‐clocked to 1GHz, so 40% faster  512MB of RAM  micro‐SD Slot  mini‐HDMI  micro‐USB for data  micro‐USB for power  40‐pin GPIO connector (same pinout as A+/B+/2B)  Size is 65mm x 30mm x 5mm Recommended Pi Zero Projects  JustBoom Amp Zero pHAT  JustBoom DAC Zero pHAT  JustBoom Digi Zero pHAT  PaPiRus Zero                         https://uk.pi‐supply.com/products/pi‐zero‐v1‐3‐with‐colour‐coded‐soldered‐header 7‐26‐18
PIS-0901
物料型号:Raspberry Pi Zero v1.3 器件简介:这是一个低成本、体积小的设备,带有预装的彩色编码引脚头,便于用户识别不同的引脚功能。 引脚分配:40针2x20公头,颜色编码为红色=5V,黄色=3V3,黑色=GND,蓝色=DNC(反向I2C),绿色=GPIO引脚。 参数特性:包括BCM2835处理器(与Pi 1相同,但超频至1GHz,速度提升40%),512MB RAM,micro-SD卡槽,mini-HDMI,micro-USB数据接口,micro-USB电源接口,40针GPIO连接器(与A+/B+/2B相同)。 功能详解:Raspberry Pi Zero v1.3现在带有摄像头端口,可以使用新的Raspberry Pi Zero摄像头适配器连接摄像头。 应用信息:推荐项目包括JustBoom Amp Zero pHAT、JustBoom DAC Zero pHAT、JustBoom Digi Zero pHAT和PaPiRus Zero。 封装信息:尺寸为65mm x 30mm x 5mm。
PIS-0901 价格&库存
很抱歉,暂时无法提供与“PIS-0901”相匹配的价格&库存,您可以联系我们找货
