PIS-0900
PIS-0900
    PISUPPLY
    RASPBERRY PI ZERO W BCM2835
PIS-0900 数据手册
      Pi Zero W with Colour Coded Soldered Header We've made setting up the Pi Zero Wireless even easier by having a Raspberry Pi Zero W that comes with a pre‐soldered colour coded header. This 40 pin 2x20 male header makes it easier for you to find the right pins.   Red = 5V  Yellow = 3V3  Black = GND  Blue = DNC (Reversed I2C)  Green = GPIO pins The Raspberry Pi Zero W takes the beloved and extremely popular Pi Zero and adds wireless LAN and Bluetooth, making it perfect for embedded Internet of Things projects. It's a tiny, low cost, low power mini computer with mini‐HDMI, and the same 40‐pin GPIO that all other Raspberry Pi boards use.  1Ghz, Broadcom BCM 2835 single‐core processor  512 MB of RAM  1 micro USB port for power supply  Compatible with existing HATs  Composite video and reset headers  CSI Camera Connector  40‐pin GPIO connector (same pinout as A+/B+/2B)  On‐board Wireless LAN ‐ 2.4 GHz 802.11 b/g/n (BCM43438)  On‐board Bluetooth 4.1 + HS Low‐energy (BLE) (BCM43438) Project ideas Take your Pi Zero W to the next level with some of these pHAT add on boards  PaPiRus Zero ‐ An ePaper display for your Raspberry Pi Zero  JustBoom DAC Zero pHAT  JustBoom Amp Zero pHAT  JustBoom Digi Zero pHAT Notes   Please be aware that your Pi Zero W WILL NOT BOOT without an SD card with a fresh image installed. SD cards that work in your Pi 2/3 or Pi Zero (non‐W) are not guaranteed to work in your new Zero W! You will require at least NOOBS 2.2.0 (27th Feb 2017) or Raspbian 2017‐02‐27 or newer. The instructions from the Raspberry Pi Foundation here will guide you on how to prepare a NOOBS card.                  https://uk.pi‐supply.com/products/pi‐zero‐w‐with‐colour‐coded‐soldered‐header 7‐26‐18
PIS-0900 价格&库存
很抱歉,暂时无法提供与“PIS-0900”相匹配的价格&库存,您可以联系我们找货
