PIS-0623
PIS-0623
    PISUPPLY
    QTUM STAKEBOX
PIS-0623 数据手册
    QTUM Stakebox StakeBox and?QTUM have partnered together to bring?you the QTUM StakeBox ‐ a?device that allows you to stake your QTUM cryptocurrency and make a return on your investment.? QTUM is a Proof‐of‐Stake cryptocurrency which means you don't require a powerful computer rig to earn rewards. Staking?is the process of securing the network with your coin weight, which in turn rewards you with new QTUM. The stakebox?requires little setup allowing you to get up and running in no time at all and includes all the essential?accessories. Set it up and start earning crypto rewards* without needing to buy an expensive?computer rig.? What's Inside  Raspberry Pi 3 Model B  QTUM?Case  2.5A International Power Supply Unit  16GB SD card with?QTUM software  HDMI cable Raspberry Pi 3 Specifications  Processor o Broadcom BCM2387 chipset o 1.2GHz Quad‐Core ARM Cortex‐A53 o  o o  o  o  o  o 802.11 b/g/n Wireless LAN and Bluetooth 4.1 (Bluetooth Classic and LE) GPU Dual Core VideoCore IV? Multimedia Co‐Processor. Provides Open GL ES 2.0, hardware‐accelerated OpenVG, and 1080p30 H.264 high‐profile?decode Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and?DMA infrastructure Memory 1GB LPDDR2 Operating System Boots from Micro SD card, running a version of the Linux operating system or?Windows 10 IoT Dimensions 85 x 56 x 17mm Power Micro USB socket 5V1, 2.5A *staking interest depends on the specific cryptocurrency and other conditions and is not guaranteed by StakeBox                                        https://uk.pi‐supply.com/products/qtum‐stakebox 6‐26‐18
PIS-0623 价格&库存
很抱歉,暂时无法提供与“PIS-0623”相匹配的价格&库存,您可以联系我们找货
