PIS-0396
PIS-0396
    PISUPPLY
    RAK811 BREAKOUT BOARD 433MHZ
PIS-0396 数据手册
      RAK811 Breakout Board with SMA + IPX connectors Simple breakout board for using the RAK811/811‐N module standalone or attached to any UART device. What is it? It’s a simple breakout board which has a 3.3V regulator, SMA, and IPX mounting place, SWD programming header and everything else as header output. You can used this to test your RAK811 module without any hassle. Why did you make it? There’s currently just the Wisnode Arduino shield thing for the RAK811. If you wanted a simple thing which just takes the RAK811 without a big clunky and unneeded PCB around it. What makes it special? It’s small and open source! Frequency 433MHz 470MHz 868MHz 915MHz 923MHz   https://uk.pi‐supply.com/products/rak811‐breakout‐board‐sma‐ipx‐connectors?_pos=1&_sid=4a9e9ec4a&_ss=r/7‐30‐19
PIS-0396 价格&库存
很抱歉,暂时无法提供与“PIS-0396”相匹配的价格&库存,您可以联系我们找货
