RAK811 Breakout Board with SMA + IPX
connectors
Simple breakout board for using the RAK811/811‐N module standalone or attached
to any UART device.
What is it?
It’s a simple breakout board which has a 3.3V regulator, SMA, and IPX mounting
place, SWD programming header and everything else as header output. You can
used this to test your RAK811 module without any hassle.
Why did you make it?
There’s currently just the Wisnode Arduino shield thing for the RAK811. If you
wanted a simple thing which just takes the RAK811 without a big clunky and
unneeded PCB around it.
What makes it special?
It’s small and open source!
Frequency
433MHz
470MHz
868MHz
915MHz
923MHz
https://uk.pi‐supply.com/products/rak811‐breakout‐board‐sma‐ipx‐connectors?_pos=1&_sid=4a9e9ec4a&_ss=r/7‐30‐19
很抱歉,暂时无法提供与“PIS-0397”相匹配的价格&库存,您可以联系我们找货
