RPI-030
RPI-030
    PISUPPLY
    RASPBERRY PI ZERO BCM2835 EVAL
RPI-030 数据手册
    Raspberry Pi Zero v1.3 with Soldered Header SKU: RPI-030 The Raspberry Pi Zero is now faster and more powerful! It’s super low cost and smaller than the Raspberry Pi 3. The Raspberry Pi Zero v1.3 now comes complete with a soldered 40 pin header, so no need for you to break out the soldering iron! Description The Raspberry Pi Zero v1.3 is super low cost and smaller than the Raspberry Pi 3 and comes with a pre-soldered header. The Raspberry Pi Zero v1.3 now comes complete with a camera port. Using the new Raspberry Pi Zero Camera Adapter, you can now connect a Raspberry Pi camera to your Zero. HAT Compatibility Note The Pi Zero is fully compatible with all HAT breakout boards, as it features the same 40 Pin GPIO as the Raspberry Pi 2/B+/A+         Raspberry Pi Zero includes: BCM2835 (same as Pi 1) but up-clocked to 1GHz, so 40% faster 512MB of RAM micro-SD Slot mini-HDMI micro-USB for data micro-USB for power 40-pin GPIO connector (same pinout as A+/B+/2B) Size is 65mm x 30mm x 5mm   Additional information WEIGHT 0.04 kg DIMENSIONS 3 x 9 x 10 cm                                      https://www.pi‐supply.com/product/raspberry‐pi‐zero‐v1‐3‐soldered‐header/2/9/18
RPI-030 价格&库存
很抱歉,暂时无法提供与“RPI-030”相匹配的价格&库存,您可以联系我们找货
