Arduino Uno to Raspberry Pi Adapter
This adapter board allows you to use our range of Raspberry Pi boards with the
Arduino Uno, Genuino UNO and other Arduino boards which use the same pin
layout as the Uno design. The adapter connects the pins on the UNO to the
Raspberry Pi header and has a level shifter chip to translate the voltages used by our
Raspberry Pi HAT style boards.
Solder jumpers are provided on the board so you can set the I2C bus to connect to
either Arduino pins A4 and A5 or 16 and 17.
This kit contains the following items:
Adapter PCB Board
Header pins for the Arduino / Genuino UNO
Header pins for the Raspberry Pi GPIO header.
Please note this kit requires a soldering iron and solder to assemble.
The Arduino header pins need to be soldered from the top of the PCB board and the
2 rows of 20 pins headers need to be soldered from the bottom with the header pins
on the top of the PCB boards to allow you to install the Raspberry Pi expansion
boards
https://uk.pi‐supply.com/products/arduino‐uno‐to‐raspberry‐pi‐adapter/3‐20‐19
很抱歉,暂时无法提供与“PIS-1353”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 73+75.9158473+9.85002
