PIS-0914
PIS-0914
    PISUPPLY
    THUNDERBORG DUAL 5A MOTOR CONTRO
PIS-0914 数据手册
        ThunderBorg ‐ Dual 5A Motor Controller ThunderBorg is a powerful dual motor control board for making awesome robots with your Raspberry Pi. ThunderBorg is designed to handle up to 5A per motor connection, so it's great for bigger‐than‐your‐average‐buggy projects and making awesome robots from your Raspberry Pi. The ThunderBorg is used in our MonsterBorg Raspberry Pi robot kit. All ThunderBorg versions include:  Control BIG or small motors.  On‐board 5V regulator powers the Raspberry Pi  Runs from any battery pack or power supply from 7V to 35V  Proper 5A output per motor connection  Speed control forwards and reverse via PWM  On‐board voltage monitoring for attached batteriesv  Mounts directly onto most Raspberry Pi models  Super bright 24 Bit LED capable of over 16 million colours  Stackable! Plug in more boards to control up to 200 motors!  Controls 2x DC Motors or 4, 5 or 6 wire stepper motors  Uses I2C SCK/SDA and 3.3V/GND pins for communications  Overheat protection, under voltage lockout, and short circuit protection. We also have an optional ThunderBoard lid pack which comes with an additional:  A second super bright LED which can be independently controlled  9V style connector for either AA battery packs or 9V batteries  Convenient power switch to disconnect the batteries  Enough room to sit a 10x AA battery pack  Pre‐soldered directly onto the ThunderBorg by us.                            https://uk.pi‐supply.com/products/thunderborg‐dual‐5a‐motor‐controller 7‐26‐18
PIS-0914 价格&库存
很抱歉,暂时无法提供与“PIS-0914”相匹配的价格&库存,您可以联系我们找货
