PIS-0722
PIS-0722
    PISUPPLY
    TREZARCOIN STAKEBOX
PIS-0722 数据手册
        Trezarcoin StakeBox StakeBox and?Trezarcoin?have partnered together to bring?you the Trezarcoin StakeBox ‐ a?device that allows you to stake your Trezarcoin cryptocurrency and make a return on your investment.? Trezarcoin is a Proof‐of‐Stake cryptocurrency which means you don't require a powerful computer rig to earn rewards. Staking?is the process of securing the network with your coin weight, which in turn rewards you with new Trezarcoin. The stakebox?requires little setup allowing you to get up and running in no time at all and includes all the essential?accessories. Set it up and start earning crypto rewards* without needing to buy an expensive?computer rig. What's Inside  Raspberry Pi 3 Model B  Trezarcoin Case  2.5A International Power Supply Unit  16GB SD card with Trezarcoin software  HDMI cable Raspberry Pi 3 Specifications  Processor o Broadcom BCM2387 chipset o 1.2GHz Quad‐Core ARM Cortex‐A53 o  o o  o  o  o  o 802.11 b/g/n Wireless LAN and Bluetooth 4.1 (Bluetooth Classic and LE) GPU Dual Core VideoCore IV? Multimedia Co‐Processor. Provides Open GL ES 2.0, hardware‐accelerated OpenVG, and 1080p30 H.264 high‐profile?decode Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and?DMA infrastructure Memory 1GB LPDDR2 Operating System Boots from Micro SD card, running a version of the Linux operating system or?Windows 10 IoT Dimensions 85 x 56 x 17mm Power Micro USB socket 5V1, 2.5A Learn More  Getting started with TrezarCoin StakeBox  How to remotely access your TrezarCoin StakeBox  How to backup and restore your TrezarCoin wallet  View all guides                                               https://uk.pi‐supply.com/products/trezarcoin‐stakebox 6‐26‐18
PIS-0722 价格&库存
很抱歉,暂时无法提供与“PIS-0722”相匹配的价格&库存,您可以联系我们找货
