PIS-0107
PIS-0107
    PISUPPLY
    WIPI WIRELESS WIFI ADAPTER FOR R
PIS-0107 数据手册
                  WiPi Wireless WiFi Adapter for Raspberry Pi The Wi‐Pi module is a high performance WLAN USB module which enables the Raspberry Pi to connect to a Wi‐Fi network. The Wi‐Pi module supports 802.11n standards with data rate upto 150Mbps, as compared to older 54Mbps in 802.11g standards. It also has a higher wireless LAN bandwidth, making data transmission more efficient, whilst also supporting wireless roaming, and ensuring consistent wireless connection. The Wi‐Pi uses the latest international wireless CCA air channel detection technology, enhancing wireless performance.  Antenna ? Built‐in smart antenna  Transmission speed ? 11b ? 1/2/5.5/11Mbps, 11g ? 6/9/12/18/24/36/48/54Mbps, 11n ? up to 150Mbps  Frequency range ? 2.4GHz to 2.4835GHz  Working channel ? 1 to 13  Transmit power ? 20dBm (max)  Security features ? WPA‐PSK/WPA2‐PSK, WPA/WPA2, 64/128/152 bit WEP encryption  Operating Systems ? Debian 6.0 Linux distribution  Operating temperature ? 0?C to 40?C                                                        https://uk.pi‐supply.com/products/wipi‐wireless‐wifi‐adapter‐raspberry‐pi 6‐25‐18
PIS-0107 价格&库存
很抱歉,暂时无法提供与“PIS-0107”相匹配的价格&库存,您可以联系我们找货
