Cube:Bit Base for Power, Microbit
and Raspberry Pi
4TR‐CUBASE
A great Base for your Cube:Bit allowing easy connection of
power and signal and directly able to plug in Micro:Bit or
Raspberry Pi Zero
These bases have been especially designed to accept all 3 sizes of Cube:Bit and
provide a simple method of powering them.
Because a lot of LEDs uses a lot of power, neither the micro:bit nor the Raspberry Pi
can power them directly. We therefore provide this base plate that allows you to connect
the 5V power in 4 different ways:
1. DC Jack using a standard 2.1mm (centre positive) DC Jack you can simply plug in a 5V
DC power supply
2. Micro USB connector. Get yourself a high power USB power supply (such as the official
2.5A Raspberry Pi power supply) and simply plug it in
3. Crocodile/alligator clip positions allow you to connect power and signal using croc clips eg from a Crumble, MicroBit or similar
4. GVS pins allow you to take a standard 3-pin 2.54mm female cable and plug it directly in.
Eg from an Arduino sensor shield or directly from a 4duino Pro
There is a 40pin GPIO header that you can plug a Raspberry Pi Zero into and it will be
powered from the 5V and connect on GPIO 12 (pin 18) to the neopixel array. This is the
standard pin for driving neopixels on the Raspberry Pi. Note that there isn't room to fit a
full-size Raspberry Pi (though with a GPIO cable you could do that as well)
There is also a micro:bit connector so you can plug your micro:bit straight in. This is
powered via the 3.3V voltage regulator from the 5V so no separate power is required for
the micro:bit. This connects on Pin 0 to the Cube:Bit pixels.
As you can see, an extremely flexible and useful addition to your Cube:Bit
Dimensions: 89 x 89mm
https://shop.pimoroni.com/products/cube‐bit‐base‐for‐power‐microbit‐and‐raspberry‐pi 11‐7‐18
很抱歉,暂时无法提供与“4TR-CUBASE”相匹配的价格&库存,您可以联系我们找货
