4TR-CUBE5
4TR-CUBE5
    PIMORONI
    5X5X5-CUBE:BIT MAGICAL RGB CUB
4TR-CUBE5 数据手册
      5x5x5 – Cube:Bit Magical RGB Cubes of Awesome 4TR-CUBE5 Magical RGB Cubes of Awesome. Lovingly hand-woven from pure Rainbow by Unicorns (ed: suspicion of hyperbole) With many thanks for @LMcUnderwood for inspiring the product with her enormous Cubert 8x8x8 cube and coming up with the name Cube:Bit. Check out her blog here These wonderful cube kits can be assembled in only a few minutes with only a small screwdriver. No soldering is involved.     Every cube is made out of pre-assembled slices that have neopixel LEDs on both sides to give an all-round effect to the lighting. Learn about co-ordinates in 2D and 3D. Create wonderful visual effects and stunning indicators to sensory events on your micro:bit or Raspberry Pi Use the Cube:Bit base available separately to provide power, connect your controller, or directly plug in a micro:bit or Raspberry Pi Zero (Full size Raspberry Pi work fine of course, but don't fit directly without using an extension GPIO cable, or simply 3 femalefemale jumper cables for 5V, Gnd and GPIO18) With Raspberry Pi, use any of the neopixel code already available to drive your Cube:Bit eg. Pimoroni, Adafruit or 4tronix neopixel products. With micro:bit 4tronix have written a special Makecode package that "knows" about the shape of all the cubes and can map from x, y, z co-ordinates directly to a pixel anywhere in the cube. Write to a whole plane of pixels at once, create a moving rainbow effect in only a few lines. The possibilities are endless Oh, did we mention that you can stack them, so you can make a tower as high as you like! Dimensions:  3x3x3 is 49mm on a side  4x4x4 is 69mm  5x5x5 is 89mm                   https://shop.pimoroni.com/products/cube‐bit‐magical‐rgb‐cubes‐of‐awesome?variant=12957238427731 11‐7‐8
4TR-CUBE5 价格&库存
很抱歉,暂时无法提供与“4TR-CUBE5”相匹配的价格&库存,您可以联系我们找货
4TR-CUBE5
  • 2+1209.636262+156.48492
