4TR-BITBOT
4TR-BITBOT
    PIMORONI
    BIT:BOT
4TR-BITBOT 数据手册
    Bit:Bot 4TR BITBOT     Fully Integrated Robot for the BBC Micro:Bit This (almost) ready-assembled robot requires no soldering, no wires and nothing more than a screwdriver to complete it. The Bit:Bot fully engages children and adults alike, allowing you to explore and code the BBC Micro:Bit using any of the languages available (not all features are supported in all languages) Check out these features:           2 micro-metal gear motors. Both fully controllable in software, for both speed (0 to 100%) and direction (forward or reverse) Wheels with rubber tyres for maximum grip Really smooth metal ball front caster 12 mini neopixels in 2 sets of 6 along the arms either side. Select any colour for any pixel, produce stunning lighting effects as your Bit:Bot moves around 2 digital line following sensors. Code your own line-following robots and race them to see whose code produces the fastest lap time! 2 analog light sensors (front left and front right) so your Bit:Bot can be programmed to follow a light source such as a torch, or you could code it to go and hide in the darkest place it can find Buzzer, so you can make beeping sounds whenever you want Powered from integrated 3xAA battery holder with on/off switch and blue indicator LED Easily plug your BBC micro:bit in and out using the edge connector Expansion connections at the front for additional sensors (Ultrasonic rangefinder available now, more in development) Includes an Ultrasonic Distance Sensor (rangefinder) module. NB. BBC Micro:Bit is NOT included        https://shop.pimoroni.com/products/bit‐bot 6/27/2017
4TR-BITBOT
物料型号为:MAX31855KASA+。
器件简介为:MAX31855是一款冷结点补偿型K型热电偶数字转换器,具有高精度和低噪声的特点。
引脚分配为:1-VDD,2-GND,3-SCK,4-CS,5-SO,6-T+,7-T-,8-GND。
参数特性包括:供电电压范围为2.0V至5.5V,工作温度范围为-40°C至+125°C,精度为±1°C。
功能详解为:该器件能够将K型热电偶的模拟信号转换为数字信号,具有SPI接口,适合用于温度监测和控制系统。
应用信息为:广泛应用于工业过程控制、医疗设备、环境监测等领域。
封装信息为:KA-8封装。
4TR-BITBOT 价格&库存
很抱歉,暂时无法提供与“4TR-BITBOT”相匹配的价格&库存,您可以联系我们找货
