4TR-RBITBUG
4TR-RBITBUG
    PIMORONI
    ROBO:BIT MK2 - BUGGY FOR THE MIC
4TR-RBITBUG 数据手册
    Robo:Bit Mk2 - buggy for the micro:bit   This little buggy can be assembled very quickly using only a screwdriver. No soldering is required. Contents:  Robo:Bit robotics controller PCB  Fixings pack (battery holder, screws, mounting pillars, caster, etc.)  2 x Yellow Wheels with Tyres  2 x Motors with pre-fitted connection wires (no soldering required)  micro:bit not included, click here if you need to pick one up! Using the basic kit you can learn about:  Controlling motors with simple Forwards / Reverse controls  Controlling the speed of motors in both directions using PWM  Use a second micro:bit with the easy-to-use radio software to control the buggy  Use the motion sensor on the micro:bit to detect collision with obstacles and avoid them With the optional Ultrasonic Distance Sensor (not included):  Detect when obstacles get close and change the program to avoid the obstacles  "Follow-Me" program that tries to stay a certain distance from the object in front With the optional Line Follower Sensor Pack (not included):  Use the 2 line sensors either side of the non-reflective line to detect the line and keep the buggy on track  Write more complex programs that behave as required if you meet a T-Junction or crossing of lines  Compare different line following strategies - create a race-track and see which strategy is fastest  In combination with the distance sensor, make it avoid obstacles on the track and then reacquire the line         Essential extras Make sure you have everything you need with this handy checklist! Ultrasonic Distance Sensor for Robo:Bit Mk2              Line Follower Sensor Pack for Robo:Bit Buggy                                                              https://shop.pimoroni.com/products/robo‐bit‐mk2‐buggy‐for‐the‐micro‐bity 5‐24‐18
4TR-RBITBUG 价格&库存
很抱歉,暂时无法提供与“4TR-RBITBUG”相匹配的价格&库存,您可以联系我们找货
4TR-RBITBUG
    • 4+280.681654+36.32650
