Chibitronics Effects stickers and
stencil
CBI011
Effects Stickers generate an effect to control your LEDs (or
other output!). This pack contains four pre-programmed and
craft-friendly effects: blink, fade, twinkle and heartbeat
Circuit Stickers are electronic stickers that you can use to build glowing, sensing, and
interactive projects without any complicated equipment or programming skills. All you
need is your imagination.
Building circuits with them is fun and easy -- just stick them onto a surface like you
would with a normal sticker, and build up a circuit by sticking several stickers together
and adding a battery. They’re an approachable way to learn and create electronics
through craft, whether you’re just starting out with circuits or creating complex
interactive artworks.
light, paper-thin and flexible circuit boards cut into small, fun shapes
anisotropic conductive adhesive on the back sticks to most surfaces
can be used with virtually any conductive materials as “wiring”-- such as conductive threads and
paints or even wires and aluminium foil from your kitchen.
Chibitronics even have a great learning portal with tutorials and additional resources
Comes with a craft stencil for planning complicated circuits using accurate pad shapes
for effects and lights
https://shop.pimoroni.com/products/chibitronics-effects-stickers-and-stencil 7-25-18
很抱歉,暂时无法提供与“CBI011”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 7+167.430327+21.67531
