COM-B015
COM-B015
    PIMORONI
    JOYSTICK
COM-B015 数据手册
                                         Joystick COM-B015   Joystick COM-B015 This clicky joystick is great for DIY arcade builds, and it has a handy 5-pin connector that means connecting it is just a case of plugging in a single cable connector. We use this joystick in our new Picade and it's solid, responsive, and reliable. The feel is a little looser than the Zippyy joystick that we sell, more similar to a Japanese joystick. Pair it with a Raspberry Pi, Picade X HAT, and some arcade buttons and you've got all the controls you need to build your own arcade machine! We'd recommend also picking up one of our new Picade wiring looms, which includes a 5-pin connector to 5x Dupont connector cable that can be used with this joystick. Features  35mm black ball top  Black dust cover  8-way square restrictor gate  9mm diameter, 36mm tall shaft  5-pin connector (compatible with JST-XH cable) Notes  Pinout: up, down, right, left, ground (from pin closest to centre)  Overall dimensions (including ball-top): 106x70x95mm  Mounting plate dimensions: 60x95mm  Corner hole centres (5mm holes): 44x82mm  Centre hole centres (6mm holes): 85mm                                                https://shop.pimoroni.com/products/joystick 11‐6‐18
COM-B015 价格&库存
很抱歉,暂时无法提供与“COM-B015”相匹配的价格&库存,您可以联系我们找货
