COM0803
COM0803
    PIMORONI
    安装支架 底座安装
COM0803 数据手册
  Micro Metal Gearmotor Bracket (Pair) COM0803 These simple little brackets are the best way to securely mount our micro metal gearmotors to your project, whether it be a robot, a fan, or a pulley system. We've designed the mounting tabs to capture the nuts for easy installation. They have the same hexagonal shape as the nuts and hold them in place, so that you don't have to! The distance between the mounting hole centres is 18mm and the bolt diameters are 2mm, if you need to drill, laser cut or 3D print your own chassis to mount the motors to. These also go together great with our micro metal gearmotor to LEGO® axle adaptors, allowing you to incorporate the gearmotors into your LEGO projects. Kit contains:   2 x brackets  2 x M2 nylon nuts and bolts                                                        https://shop.pimoroni.com/products/pimoroni‐gearmotor‐bracket‐pair 5/5/2017
COM0803 价格&库存
很抱歉,暂时无法提供与“COM0803”相匹配的价格&库存,您可以联系我们找货
COM0803
    • 1+59.885351+7.75268
