COM2401
COM2401
    PIMORONI
    LCD DISPLAY LCD LIGHT VALVE
COM2401 数据手册
    LCD shutter  Small  /COM2400    Large  /COM2401      These neat little LCD panels, in two sizes, go black when a current is passed through them. Perfect for creating your own pair of "deal with it" sunglasses! Essentially single pixel LCD displays, these panels polarise and go black (completely opaque) when you pass 3V through them, and then de-polarise (become transparent) when pulled low or shorted. Easy! You can treat the LCD shutter like a low value capacitor. Once energised, they will hold their polarised/opaque state, but slowly leak charge over time and become de-polarised/transparent again. The amount of current required to charge the LCD shutter is extremely low, as with most LCDs. They are best viewed from directly in front, as other viewing angles may lower the opacity slightly. The displays are made of glass and have sharp corners, so take care when handling them. Size Outline dimensions Active area Operating voltage Operating temp. Small 36x36x2mm 31x33mm 3V -10°C-65°C Storage temp. -20°C-75°C Large 96x48x2mm 93x43mm 3V -10Ԩ-65Ԩ -20Ԩ-75Ԩ        https://shop.pimoroni.com/products/lcd‐shutter 12‐1‐17
COM2401 价格&库存
很抱歉,暂时无法提供与“COM2401”相匹配的价格&库存,您可以联系我们找货
COM2401
  • 21+64.2284021+8.31493
