PIM342
PIM342
    PIMORONI
    箱 丙烯酸 黑色 手持式 3.898" 长 x 2.598" 长(99.00mm x 66.00mm) X 0.591"(15.00mm)
PIM342 数据手册
      Coupé Red Coupé Ninja Coupé Flotilla Coupé Royale Pibow 3 B+ Coupé (Raspberry Pi 3 B+, 3, & 2) Pibow Coupé. The slim, hackable, and attractive case for the Raspberry Pi! Note: We've redesigned Pibow Coupé to be compatible with the Raspberry Pi 3 B+, 3, and 2. Due to changes in the layout of the Raspberry Pi 3 B+, older Pibows (ones with a 3/2/B+ label) will not work with Raspberry Pi 3 B+! Features  Compatible with Raspberry Pi 3 B+, 3, and 2  Extra venting, and a place for installing a heatsink if you really want to push your Pi  Super-slimline profile  Fully HAT-compatible  Works great with standoffs!  Protects your beloved Pi!  Clear top and base leave Raspberry Pi visible  GPIO cut-out with laser-etched pin labels  Leaves all ports accessible  Made from lightweight, high-quality, cast acrylic  Great for hacking and tinkering!  Made in Sheffield, UK Crafted out of five unique layers including a transparent top and base that leave your beautiful Pi visible inside. Each layer is laser-cut from colourful, high-quality, cast acrylic and once stacked they securely contain a Raspberry Pi 3 B+, 3, or 2 while leaving the primary ports, including the camera port, display port, and GPIO accessible. Weighing just over 50 grams, the case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly. The dimensions are: 99x66x15mm (WxLxH, not including bolt heads and nuts).                https://shop.pimoroni.com/products/pibow‐coupe‐for‐raspberry‐pi‐3‐b‐plus 3‐27‐18
PIM342
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
PIM342 价格&库存
很抱歉,暂时无法提供与“PIM342”相匹配的价格&库存,您可以联系我们找货
