Mini Offset Ratchet
DR-55
This super low profile driver is pocket sized and lets you work in really enclosed or restricted
areas
The low-profile head is only 22mm high, so you can easily get into all of those tight spaces that
can cause so much trouble. The built in ratchet mechanism comes with an easily switchable
ratchet lever to change direction for tightening or loosening.
Comes with four other hex-shaft bit options:
Phillips size #1
Phillips size #2
Phillips size #3
6.0mm slot head bit
These are made in Japan by a long established and highly regarded specialist tool company.
Step 1
Push out a bit with the tip of
driver.
How to change the bit
Step 2
Step 3
Push out the bit with the edge of bit
holder.
Insert the bit to be
used.
https://shop.pimoroni.com/products/mini‐offset‐ratchet6/27/2017
很抱歉,暂时无法提供与“DR-55”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 8+159.148218+20.60312
