ESP002
ESP002
    PIMORONI
    PUCK.JS
ESP002 数据手册
  Puck.js ESP002    A Smart Bluetooth Button that can be programmed wirelessly, in JavaScript! Puck.js is an intelligent Bluetooth button. With the Espruino JavaScript interpreter on its internal ARM microcontroller, software can be uploaded, debugged and modified wirelessly from any modern computer or phone, making development of embedded devices significantly easier. It has built-in sensors, lights, infrared transmitter, GPIO, and can even control other Bluetooth LE devices. What makes it special? You can get your own code working on Puck.js just a few seconds after getting it out of the box. With Web Bluetooth you don't need to install any software on your computer - just go to https://www.espruino.com/ide/ with a Web Bluetooth capable browser and you can connect instantly and start writing code. There's even a graphical programming language if you're not happy writing JavaScript. Features                 Bluetooth Low Energy  Espruino JavaScript interpreter pre‐installed  nRF52832 SoC ‐ 64MHz Cortex M4, 64kB RAM, 512kB Flash  8 x 0.1" GPIO (capable of PWM, SPI, I2C, UART, Analog Input)  9 x SMD GPIO (capable of PWM, SPI, I2C, UART)  ABS plastic rear case with lanyard mount  Silicone cover with tactile button  MAG3110 Magnetometer  IR Transmitter  Built in thermometer, light and battery level sensors  Red, Green and Blue LEDs  NFC tag programmable from JavaScript  Pin capable of capacitive sensing  Weight: 14g in plastic case, 20g in packaging  Dimensions of plastic case: 36mm dia, 12.5mm thick  Dimensions of bare PCB: 29mm dia, 9mm thick        https://shop.pimoroni.com/products/puck‐js  4/17/2017
ESP002 价格&库存
很抱歉,暂时无法提供与“ESP002”相匹配的价格&库存,您可以联系我们找货
