HC-TH
HC-TH
    PIMORONI
    THIRD HAND V2
HC-TH 数据手册
  Third Hand V2  HC-TH Traditional helping hands are flimsy, hard to adjust, and lightweight. That’s why we like the Hobby Creek Third Hand. This Third Hand is made from premium materials, is easy to use, customizable, and built to last. Features  SNAPLINE Adjustable Arms - Four 15" Arms - 3D positioning - 20 independent joints  Tunable Arm Technology - Stiff (1lb per arm 10lb total) or Super Precise (Lubrication included)  Interchangeable Alligator Clips - 360 Degree Rotation - Clear Silicone Covers - 4 large clips and 2 extra large clips  Heavy Duty Powder Coated Base Plate - Cast Aluminum - Anti Slip Rubber Bottom Easy to Use Arms can bend and rotate any direction providing unlimited working angles. The individual arm segments allow the Third Hand to be easily adjusted and then stay in place when you need it to, simply place the arms where you want them. Durable The Third Hand base is precision machined aluminum and beautifully anodized to protect it from damage. The bottom of the base is also protected by an anti-slip rubber bottom that keeps the Third Hand from slipping around on your workbench. The Third Hand will last you a lifetime!                                          https://shop.pimoroni.com/products/third‐hand‐v2/2‐5‐19
HC-TH 价格&库存
很抱歉,暂时无法提供与“HC-TH”相匹配的价格&库存,您可以联系我们找货
