IFIX-EU145391
IFIX-EU145391
    PIMORONI
    MAHI DRIVER KIT - 48 BIT DRIVER
IFIX-EU145391 数据手册
Mahi Driver Kit - 48 Bit Driver Kit • IFIX EU145391 The Mahi Driver Kit includes iFixit’s 1/4" aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top—plus 48 driver bits. Spanners, Squares, and Splines—oh my! In addition to standard Phillips and Flathead, this bit kit includes all the 1/4" form factor bits you’ll need to handle the toughest and torque-iest fasteners in any home or shop project. All our next-gen bit kits have been re-engineered for maximum utility. The bit kit lid is held in place with magnets to increase product lifespan (no more broken hinges or clasps) and also mounts to the back of the bit kit case to keep it out of the way while you do your work. Or, if you need help keeping your screws and parts organized, use the lid’s integrated sorting tray. Toolkit Includes • Easy-to-Open Magnetized Case • Lid with Built-in Sorting Tray • 1/4" Aluminum Bit Driver • 1/4" Screwdriver Bits • Phillips - 0, 1, 2, 3 • Flathead - 4, 6, 8 mm • Hex Security - 4, 5, 6, 7, 8 mm • Hex Security SAE - 1/8, 9/64, 5/32, 3/16, 7/32, 1/4 • Pozidriv - PZ1, PZ2, PZ3 • Spanner - 4, 6, 8, 10, 12 • Square - 2, 3 • Spline - M5, M6, M8 • Torx Security - TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40 • Tri-wing 1, 2, 3, 4 • Clutch 1, 2, 3 • Schrader Valve • 1/4" Driver to 1/4" Socket SPECIFICATIONS • Bit Material: 6150 Steel • Driver Material: Anodized Aluminum • Case Material: ABS • Foam: EVA https://shop.pimoroni.com/products/mahi-driver-kit-48-bit-driver-kit 6-11-18
IFIX-EU145391 价格&库存
很抱歉,暂时无法提供与“IFIX-EU145391”相匹配的价格&库存,您可以联系我们找货
IFIX-EU145391
    • 4+348.302754+45.05828
