KBOT003
KBOT003
    PIMORONI
    KITTY CASE FOR MICRO:BIT - BLUE
KBOT003 数据手册
    Kitty Case for micro:bit Increase your micro:bit cuteness factor to over NINE THOUSAND with these soft rubber cases. They'll protect your micro:bit but still give you access to all of the ports, buttons, and lights. The Kitty Case is made from hard-wearing, soft, flexible rubber, making it a cinch to fit or remove it. The white piece lets you see the labels on the edge connector and access the pads with crocodile clips, or you can remove it altogether if you need to use the whole edge connector. You can access the three buttons, micro-USB, and JST connectors through cutouts in the case, and the rubber over the LED matrix diffuses the lights beautifully. Orange /KBOT001 Yellow /KBOT002 Blue /KBOT003 Red /KBOT004                                                         https://shop.pimoroni.com/?q=KBOT003 3‐7‐18
KBOT003 价格&库存
很抱歉,暂时无法提供与“KBOT003”相匹配的价格&库存,您可以联系我们找货
