Power for micro:bit
MNK00074
This tiny board has a standard DC barrel jack socket at one
end and provides a regulated 3.3V output that you can use to
power your micro:bit using the JST battery connector attached
to wires coming from the other end of the board.
You might want to use a MonkMakes Power for micro:bit board if you want to use a AC
to DC adapter, solar panels, or other sources of power that are not the 3V or so that the
micro:bit is expecting. The Power for micro:bit will accept an input voltage of 4.5 to 12V
DC from its standard DC barrel jack socket and convert it into a pleasantly regulated
3.3V for your micro:bit.
The advantages of using a Power for micro:bit instead of say a USB 5V power
supply are firstly that some USB 5V adaptors can cause problems with the micro:bit
(see micro:bit’s safety guidelines) and secondly because the micro:bit’s battery
connector is connected directly to the 3V alligator clip-able connector of the micro:bit,
you can supply other things that are connected to the micro:bit with a lot more than the
allowed 90mA. In fact you can supply up to 700mA. This makes the board great for use
with things like NeoPixel strips or servomotors that need a bit more current.
AC Power
If you need to power your micro:bit project for long periods of time, then you are going
to get sick of changing the batteries all the time. By using an AC adapter (not included,
but 6V recommended) you can power your micro:bit indefinitely.
Higher micro:bit 3V output Current
When powered from USB power, your micro:bit can only supply a maximum of 90mA of
current through its 3V connector. This means that powering Neopixel LED displays or
servomotors that need more current, may not work, or be reliable. The MonkMakes
Power for micro:bit boosts this maximum output current to a much more respectable
700mA. Enough to power far more Neopixels (the exact number depends on LED
brightness).
Using Bigger Batteries
The standard AAA battery pack works well, but will only last for a few days of
continuous use of the micro:bit. By using the Power for micro:bit with a bigger battery
pack with a DC barrel jack (you can achieve much greater battery life). For example,
using a 4 x AA battery pack should provide roughly 4 times the battery life that you
would expect from a AAA battery pack.
Specification
Input connector: 2.1mm DC barrel jack connector positive center connector.
Output connector: JST-2.0mm on flying leads
Voltage regulator IC: LD1117-3.3V – datasheet
https://shop.pimoroni.com/products/power‐for‐micro‐bit/2‐5‐19
很抱歉,暂时无法提供与“MNK00074”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 12+121.7504312+15.82389
