MOPI003
MOPI003
    PIMORONI
    MOPI 2: HOT-SWAP MOBILE POWER FO
MOPI003 数据手册
      MoPi 2: Hot-Swap Mobile Power for the Pi MOPI003 MoPi-2 is mobile and 24/7 power for the Pi 2 and Pi 3 boards. On your bike, up a tree, or for your home server: we've got you covered! MoPi-2 features:  Two power inputs via standard screw terminals — for standard batteries, car power sockets, old laptop, supplies, solar panels, wall adapters and more  Hot-swap power replacement without stopping work  Shudown the Pi cleanly when batteries discharge  Right-angled power switch accessible even another PCB is stacked on top  Usable as a UPS (uninterruptible power supply) by attaching both batteries and mains  Wide input voltage range: 6.5V to 24V 1  Ability to deliver up to 2.5A @ +5V to the Pi and attached additional PCBs or devices  Low power consumption: 15mA when is working, 0.5mA when is sleeping and only 15 µA when is off ! (more than 10 times less than the average battery self discharge rate)  Auto-off when input voltage reaches 6.0V, protecting the batteries from over-discharging.  Additional 2-pin terminal for an external battery charger (this is just a gate, all charging functionality depends on the charger itself)  On-board LED indicators and on screen Linux system notifications  Configuration of multiple battery chemistries and number of cells from a UI on the Pi  Full API in Python, plus a shell-friendly command-line interface  Very low-profile (3.5 mm), bottom entry, 40-pin GPIO connector allowing stacking of other boards on top of the MoPi-2  PCB pads for external power switch and +5V  Control of external 5V relay  Two-way communication via the I2C bus  Remote power-off: tell MoPi-2 to power down the Pi when logged-in remotely (after a clean shutdown, of course)  Timer-based wake-up: tell MoPi-2 what time you want your Pi to wakeup, then power it down and MoPi-2 will boot the Pi as requested  Supports Raspberry Pi 2, Raspberry Pi 3 and Raspberry Pi 3 B+ models. Many more details, including a setup guide, can be found here   Warnings!!!  DO NOT plug MoPi-2 onto your Pi while the Pi is powered up!  DO NOT touch electronic components when they're powered up — you may damage them, or burn your fingers!  AVOID handling circuit boards when charged with static!  ALWAYS read the small print on all components supplied with your MoPi-2  ALWAYS treat batteries and other power supplies with respect — if abused the energy they contain may surprise you in dangerous ways!  DO NOT feed MoPi-2 to your dog, eat nuts if you're allergic to them, or lose your sense of humour                         https://shop.pimoroni.com/products/mopi‐2‐hot‐swap‐mobile‐power‐for‐the‐pi 8‐20‐18
MOPI003 价格&库存
很抱歉,暂时无法提供与“MOPI003”相匹配的价格&库存,您可以联系我们找货
