PIM145
PIM145
    PIMORONI
    ESP8266 PHAT
PIM145 数据手册
    ESP8266 pHAT PIM145 Tinker with WiFi on your Pi Zero with ESP8266 pHAT! We've taken the ESP8266 (ESP-12F) module and added the necessary circuitry to allow it to interface cleanly with the Raspberry Pi via serial communication. ESP8266 pHAT also provides some GPIO, and one ADC channel, that we've broken out for you to use alongside a small prototyping area where you can add sensors, or other components. There is a thriving community building up around the ESP8266 platform with custom firmware, programming tools, and guides. Check out http://www.esp8266.com/ for more information! Richard Hayler has written a blog post about setting up your ESP8266 pHAT and communicating with it. The MagPi described ESP8266 pHAT as "one for serious IoT project makers". Features         WiFi connectivity over serial (up to 1mbps)  802.11 b/g/n WiFi  80MHz 32‐bit MCU  10‐bit ADC (0 ‐ 1V)  WPA/WPA2 security support  WEP/TKIP/AES encryption  Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W  Female and male header require soldering  Software ESP8266 pHAT doesn't have a Python library, like most of our other HATs and pHATs, but instead requires commands to be passed over serial from a terminal emulator like Minicom. Our getting started guide shows you exactly how to get everything set up, including installing and using Minicom, connecting to WiFi, and polling for data. Notes   This module is not a replacement for a WiFi dongle! It is designed for people who wish to  experiment with the ESP8266 platform ‐ if you just want WiFi connectivity you'd be better off  using the Official Raspberry Pi WiFi Dongle instead.  Please be aware that some variants of the ESP8266 can have pins 4 and 5 reversed.        https://shop.pimoroni.com/products/esp8266‐phat 4/19/2017
PIM145 价格&库存
很抱歉,暂时无法提供与“PIM145”相匹配的价格&库存,您可以联系我们找货
