PIM172
PIM172
    PIMORONI
    CASE PLASTIC MULTIPLE
PIM172 数据手册
  Pibow Zero Case for Raspberry Pi Zero version 1.3 PIM172 The Raspberry Pi Zero has been upgraded to include a camera port, display it with pride in this eye-catching new Pibow. Note that this is the case for the Raspberry Pi Zero v1.3 only. This case is not compatible with the Pi Zero W or the Pi Zero v1.2 (without camera connector). Does not include a Raspberry Pi Zero v1.3! Features:           Compatible with Raspberry Pi Zero v1.3   Super‐slimline profile  Fully HAT/pHAT compatible  Protects your beloved Pi Zero!  Clear top and base leave Raspberry Pi Zero visible  GPIO cut‐out  Leaves all ports accessible (encloses micro‐SD)  Made from lightweight high‐quality cast acrylic  Great for hacking and tinkering!  Made in Sheffield, UK  Crafted out of four unique layers including a transparent top and base that leave your beautiful Pi visible inside. Each layer is laser-cut from colourful high-quality cast acrylic and once stacked they securely contain a Raspberry Pi Zero while leaving the primary ports and GPIO accessible. This case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly        https://shop.pimoroni.com/products/pibow‐zero‐ver‐1‐3  5/8/2017
PIM172 价格&库存
很抱歉,暂时无法提供与“PIM172”相匹配的价格&库存,您可以联系我们找货
