PIM262
PIM262
    PIMORONI
    PI ZERO W STARTER KIT
PIM262 数据手册
      Pi Zero W Starter Kit PIM262   A great bundle of things you need to get up and running with the new Pi Zero W! Including an SD card with operating system pre-loaded, a smart and colourful Pibow Zero W case, and even one of our lovely Blinkt! multicolour LED strips to take your first steps with coding in Python! Kit includes           Pi Zero W (header requires soldering, or try a no‐solder hammer header)  Pibow case  8GB micro‐SD card with operating system pre‐loaded  Blinkt! multicolour LED strip  Male 2x20 pin header  50cm USB A to micro‐B cable  USB A (female) to micro B (male) adaptor  mini to full‐size HDMI adaptor  Sticker sheet (personalise your Pibow!)  Comes in a reusable kit box  The built-in wireless LAN and Bluetooth on the Pi Zero W frees up the micro-USB port, and makes for a really tiny package when using the Zero W in embedded, headless Internet of Things projects. Or why not use a Bluetooth mouse and keyboard, and hide your Pi behind your monitor or TV? Our beautiful Pibow case will keep your Pi Zero W protected from bumps and bruises. It has a clear top layer, and frosted red, purple, and blue layers. The clever design leaves the GPIO pins free, letting you attach our add-on boards like the Blinkt! while your Pi is still safely ensconced in its case. You can use the included sticker sheet to personalise your Pibow! The included 8GB micro-SD card comes pre-loaded with the Raspbian operating system. Just remove it from the larger SD card adaptor, pop it into the slot on your Pi Zero W before putting it into the Pibow case, and you'll be up-and-running in next to no time Our Blinkt! multicolour LED strip is the perfect way to take your first steps with coding in Python. Our Getting Started with Blinkt! guide will teach you the basics, and there's a bunch of code examples in the Blinkt! GitHub code repository to give you an idea of what's possible. Features         Blinkt! with eight APA102 RGB LEDs  Pi Zero W with single core CPU and built‐in wireless LAN and Bluetooth  Pibow Zero W acrylic case  8GB micro‐SD card with NOOBS 2.2 pre‐loaded  Adaptor kit  50cm USB A to micro‐B cable (power your Pi from an existing charger or computer)  Python library  https://github.com/pimoroni/blinkt  Female and male headers require soldering  Software Our Python library will give you full control over your Blinkt! There's even a nifty one-line installer to get everything set up super-quick. There's details on how to get started in our tutorial.        https://shop.pimoroni.com/products/pi‐zero‐w‐starter‐kit 4/13/17
PIM262 价格&库存
很抱歉,暂时无法提供与“PIM262”相匹配的价格&库存,您可以联系我们找货
